Hello, first time posting question here so apologies if I omit something obvious or format incorrectly.
I am attempting to convert a Flex web application I inherited at work to a JavaScript application for enhanced functionality and better future stability.
I require my end users to be able to click on points/polylines to get their attributes, and to be able to toggle layers contained in an ArcGISDynamicMapServiceLayer (contains 10+ individual layers).
I've achieved both these functionalities in separate dev projects (one project using a LayerList widget allowing toggling of individual layers within the map service, and the other project using a popup while using an executeIdentifyTask with a map.on("click") function to get feature attributes.
Once I attempt to combine these functionalities, I run into buggy issues, ex:
- Each LayerList widget containing layers from ALL my ArcGISDynamicMapServiceLayers (I have 4, attempting to separate their toggle-ability into separate AccordionContainers to keep them organized.
- All layers seem to be out of scale, even if they are set to be viewable at any scale.
- LayerList check boxes have no functionality behind them.
Is it possible to combine the functionalities of a ArcGISDynamicMapServiceLayer, LayerList, and popup + identify task upon "click"?
I tried using FeatureLayers, but performance suffered to the point of not being usable.
Thanks for any and all responses!
Will attempt to post sample code. New to JavaScript.
FYI I am working in NetBeans 8.0.2.
EDIT: script post attempt below:
var popup = new Popup({
lineSymbol: new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([0, 245, 255, 0.85]), 8),
markerSymbol: new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, 10,
new Color([0, 255, 0, 0.25]),
new Color([0, 245, 255, 0])))
}, domConstruct.create("div"));
var map = new Map("mapDiv", {
basemap: "national-geographic",
center: [-83.7, 33.9],
zoom: 6,
infoWindow: popup
map.on("load", mapReady);
var IT_ml = "MapService_URL";
map.addLayer(new ArcGISDynamicMapServiceLayer(IT_ml));
var LL1 = new LayerList({
map: map,
layer: [ArcGISDynamicMapServiceLayer(IT_ml)]
}, "ow_layers");
LL1.startup();
function mapReady() {
map.on("click", executeIdentifyTask);
//create identify tasks and setup parameters
identifyTask = new IdentifyTask(IT_ml);
identifyParams = new IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [0, 2, 3, 10];
identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
identifyParams.width = map.width;
identifyParams.height = map.height;
function executeIdentifyTask(event) {
identifyParams.geometry = event.mapPoint;
identifyParams.mapExtent = map.extent;
var deferred = identifyTask
.execute(identifyParams)
.addCallback(function (response) {
return arrayUtils.map(response, function (result) {
var feature = result.feature;
var layerName = result.layerName;
feature.attributes.layerName = layerName;
if (layerName === xyz) {
var xxxTemplate = new InfoTemplate("xyz",
"field1: ${field1}</br>field2: ${field2}");
feature.setInfoTemplate(xxxTemplate);
return feature;
map.infoWindow.setFeatures([deferred]);
map.infoWindow.show(event.mapPoint);
