Hi all,
I am trying to iterate zonal statistics on many rasters (+200) over many shapefiles (+30), and step through the shapefiles such that each output table will be calculated across all raster for one shapefile. For instance, shapefile #1 processes all zonal statistics for all rasters and merges it to one table, then shapefile #2 does the same, and so on until all shapefiles have been processed. Any help/advice would be greatly appreciated! Below is the code I am currently working with.
# Import system modules
import arcpy, sys, os, string, glob
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Overwrite pre-existing files
#Get the raster datasets in the input workspace and loop through them from the start
def zonal_climate_fire():
for ws in listWS:
arcpy.env.workspace = ws
rasterlist = arcpy.ListRasters()
shplist = arcpy.ListFeatureClasses()
for k in rasterlist:
for i in shplist:
out_tbl = tbl + "\\" + k + "_ZStats"
print '==============================================='
print 'Zonal Statistics based on fire occurence : ' + k[6:-3]
print '......'
# Preform zonal statistics on the polygon file within the variable 'znlyr'
z = arcpy.gp.ZonalStatisticsAsTable_sa(i, InZnValFld, k, out_tbl, "DATA", "MIN_MAX_MEAN")
# Create a new field to add the filename information
arcpy.AddField_management(z, fieldname1, "DOUBLE")
arcpy.AddField_management(z, fieldname2, "DOUBLE")
# Add the Year value from the filename to the new field
arcpy.CalculateField_management(z, fieldname1,k[6:-3])
arcpy.CalculateField_management(z, fieldname2,k[11:])
arcpy.Append_management(z, Template, "","","")
#--------------------Main to set variables--------------------------------------------------
znshp = "C:\\tmp\\znshp\\"
grd = "C:\\tmp\\grd\\"
tbl = "C:\\tmp\\tbl\\"
InZnValFld = "ID"
fieldname1= "Year"
fieldname2= "Month"
Template = "C:\\tmp\\tbl\\Template.dbf"
#Creates a list of multiple workspaces
listWS = [grd, znshp]
zonal_climate_fire ()
Thank you all in advance,
Nate
