i was trying to add a custom picture.png file for features and a label to it
for example:
buildingImage.png+(Building Id)
went to through some examples, but didn't helped me.
Any suggestions
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"Content-Type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=utf-8"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>FeatureTable <SPAN class="operator token">-</SPAN> Custom Menu Items<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.26%2Fdijit%2Fthemes%2Fclaro%2Fclaro.css" target="_blank">https://js.arcgis.com/3.26/dijit/themes/claro/claro.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.26%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.26/esri/css/esri.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.26%2F" target="_blank">https://js.arcgis.com/3.26/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #map <SPAN class="punctuation token">{</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/graphicsUtils"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/query"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/parser"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/ready"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/ContentPane"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/BorderContainer"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>
FeatureLayer<SPAN class="punctuation token">,</SPAN> Extent<SPAN class="punctuation token">,</SPAN> graphicsUtils<SPAN class="punctuation token">,</SPAN> Query<SPAN class="punctuation token">,</SPAN> Map<SPAN class="punctuation token">,</SPAN>
dom<SPAN class="punctuation token">,</SPAN> parser<SPAN class="punctuation token">,</SPAN> ready<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> ContentPane<SPAN class="punctuation token">,</SPAN> BorderContainer
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">ready</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"dark-gray"</SPAN><SPAN class="punctuation token">,</SPAN>
extent<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>xmax<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">13035353.854156237</SPAN><SPAN class="punctuation token">,</SPAN> xmin<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">13053431.211345658</SPAN><SPAN class="punctuation token">,</SPAN>
ymax<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4038351.1313028745</SPAN><SPAN class="punctuation token">,</SPAN> ymin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4034089.766975982</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">102100</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"latestWkid"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">3857</SPAN><SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Load a FeatureTable to the application once map loads</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> loadTable<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">loadTable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// editable FeatureLayer</SPAN>
<SPAN class="keyword token">var</SPAN> myFeatureLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver6.arcgisonline.com%2Farcgis%2Frest%2Fservices%2FRedlandsEmergencyVehicles%2FFeatureServer%2F1" target="_blank">https://sampleserver6.arcgisonline.com/arcgis/rest/services/RedlandsEmergencyVehicles/FeatureServer/1</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
mode<SPAN class="punctuation token">:</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>MODE_ONDEMAND<SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fLayer2"</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>myFeatureLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"claro esri"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/BorderContainer"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"design:'headline'"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"width:100%; height:100%;"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'center', splitter:true"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"height:50%"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"bot"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'bottom', splitter:true"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
