Hi,I use this code to open Network Dataset, but it fails with HRESULT on datasetContainer3.get_DatasetByName(). public static ESRI.ArcGIS.Geodatabase.INetworkDataset OpenNetworkDataset1(ESRI.ArcGIS.Geodatabase.IWorkspace networkDatasetWorkspace, System.String networkDatasetName, System.String featureDatasetName) { if (networkDatasetWorkspace == null || networkDatasetName == "" || featureDatasetName == null) { return null; } ESRI.ArcGIS.Geodatabase.IDatasetContainer3 datasetContainer3 = null; switch (networkDatasetWorkspace.Type) { case ESRI.ArcGIS.Geodatabase.esriWorkspaceType.esriFileSystemWorkspace: // Shapefile or SDC network dataset workspace ESRI.ArcGIS.Geodatabase.IWorkspaceExtensionManager workspaceExtensionManager = networkDatasetWorkspace as ESRI.ArcGIS.Geodatabase.IWorkspaceExtensionManager; // Dynamic Cast ESRI.ArcGIS.esriSystem.UID networkID = new ESRI.ArcGIS.esriSystem.UIDClass(); networkID.Value = "esriGeoDatabase.NetworkDatasetWorkspaceExtension"; ESRI.ArcGIS.Geodatabase.IWorkspaceExtension workspaceExtension = workspaceExtensionManager.FindExtension(networkID); datasetContainer3 = workspaceExtension as ESRI.ArcGIS.Geodatabase.IDatasetContainer3; // Dynamic Cast break; case ESRI.ArcGIS.Geodatabase.esriWorkspaceType.esriLocalDatabaseWorkspace: // Personal Geodatabase or File Geodatabase network dataset workspace case ESRI.ArcGIS.Geodatabase.esriWorkspaceType.esriRemoteDatabaseWorkspace: // SDE Geodatabase network dataset workspace ESRI.ArcGIS.Geodatabase.IFeatureWorkspace featureWorkspace = networkDatasetWorkspace as ESRI.ArcGIS.Geodatabase.IFeatureWorkspace; // Dynamic Cast ESRI.ArcGIS.Geodatabase.IFeatureDataset featureDataset = featureWorkspace.OpenFeatureDataset(featureDatasetName); ESRI.ArcGIS.Geodatabase.IFeatureDatasetExtensionContainer featureDatasetExtensionContainer = featureDataset as ESRI.ArcGIS.Geodatabase.IFeatureDatasetExtensionContainer; // Dynamic Cast ESRI.ArcGIS.Geodatabase.IFeatureDatasetExtension featureDatasetExtension = featureDatasetExtensionContainer.FindExtension(ESRI.ArcGIS.Geodatabase.esriDatasetType.esriDTNetworkDataset); datasetContainer3 = featureDatasetExtension as ESRI.ArcGIS.Geodatabase.IDatasetContainer3; // Dynamic Cast break; } if (datasetContainer3 == null) return null; ESRI.ArcGIS.Geodatabase.IDataset dataset = datasetContainer3.get_DatasetByName(ESRI.ArcGIS.Geodatabase.esriDatasetType.esriDTNetworkDataset, networkDatasetName); return dataset as ESRI.ArcGIS.Geodatabase.INetworkDataset; // Dynamic Cast }
