I am using react-arcgis for React App. I want to use Scene instead of Map but API does not load with Scene while it works properly with Map module.
<SPAN class="keyword token">import</SPAN> React <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'react'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">import</SPAN> <SPAN class="punctuation token">{</SPAN> Scene <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'react-arcgis'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//import { Scene } from '@esri/react-arcgis';</SPAN>
<SPAN class="keyword token">import</SPAN> <SPAN class="punctuation token">{</SPAN> Row<SPAN class="punctuation token">,</SPAN> Col <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'reactstrap'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">import</SPAN> <SPAN class="string token">'./south.css'</SPAN>
<SPAN class="keyword token">import</SPAN> SouthWidget <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'./SouthWidget'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">export</SPAN> <SPAN class="keyword token">default</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">SouthRegion</SPAN> <SPAN class="keyword token">extends</SPAN> <SPAN class="token class-name">React<SPAN class="punctuation token">.</SPAN>Component</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">constructor</SPAN><SPAN class="punctuation token">(</SPAN>props<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">super</SPAN><SPAN class="punctuation token">(</SPAN>props<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>state <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
viewProperties<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">67.110382</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">24.8776361</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
scale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">220000</SPAN><SPAN class="punctuation token">,</SPAN>
popup<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
dockEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
dockOptions<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Disables the dock button from the popup</SPAN>
buttonEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">// Ignore the default sizes that trigger responsive docking</SPAN>
breakpoint<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bottom-left"</SPAN>
<SPAN class="token function">render</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>
<SPAN class="operator token"><</SPAN>div className<SPAN class="operator token">=</SPAN><SPAN class="string token">"page-wrapper"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div className<SPAN class="operator token">=</SPAN><SPAN class="string token">"container-fluid"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>Row<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>Scene
className<SPAN class="operator token">=</SPAN><SPAN class="string token">"scene__container"</SPAN>
style<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">{</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'100vw'</SPAN><SPAN class="punctuation token">,</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'90vh'</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN>
mapProperties<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'satellite'</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN>
viewProperties<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>state<SPAN class="punctuation token">.</SPAN>viewProperties<SPAN class="punctuation token">}</SPAN>
<SPAN class="operator token"><</SPAN>SouthWidget<SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>Scene<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>Row<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
