I would like to show and hide the loading wheel while the view is updating, but I would like to hide the loading wheel for drag (panning map) and extent change event. How can I achieve it? Alternatively, is there a way to monitor the renderer update?
The current code below show loading wheel any updates and it looks very busy all the time.
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'updating'</SPAN><SPAN class="punctuation token">,</SPAN> updating <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>updating<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#loading'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#loading'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
