Hello
I have configured proxy on server so that secured services could be accessible without authentication
The proxy is working well I can see secured map services on my JavaScript API applications. Feature services are visible but they are not editable after installing the proxy.
I have used the template picker widget and I am able to select the layer in the template picker. However when I click on the map to add a point it doesn't work.
I thought it was because I had editor tracking enabled (what doesn't seem to make sense when you use the proxy). However, even after disabling the editor tracking and publishing the feature service again, it is not editable.
All applications were developed with the JavaScript API.
Has anyone run into the same problem? I appreciate any suggestion on this
Thank you very much
Adriana
