Good Afternoon Everyone. I am finally branching out of the WPF and SL API's into the JavaScript API. I have been working this for a couple days now and just don’t know if I am at a limitation of the API version I am using or if it’s a simple mistake. I am using v3.5 of the Javascript API and have included a copy of the code in the attachment. Basically everything is working find until I set the render to the dynamic map service layer. Once I
add the render nothing shows up. If it’s a limitation of the version we can stand up the newest but I wanted to run it by you first to make sure it's not a
dumb mistake. I had to remove the full server uri's because I am on a closed network but it should be easy enough to re-create. Thanks in advance.
V/R,
Josh
