When creating a replica through the REST API, is it possible to return all records from a table, but without bringing all of the related records with it? A simplified example of my issue is like this:
I have three tables: BUILDING, BUILDING_INSPECTION, and INSPECTOR. BUILDING_INSPECTION has a 1:M relationship with BUILDING and INSPECTOR has a M:1 relationship with BUILDING_INSPECTION.
I want to create a replica of the data based on an envelope that contains a subset of the BUILDING records. Obviously, I only want the BUILDING_INSPECTION records related to the BUILDING records in the specified envelope, so the queryOptions for these layers are like this:
BUILDING :
Query Option: useFilter
useGeometry: true
includeRelated: (ignored since queryOption is useFilter)
BUILDING_INSPECTION :
Query Option: none
useGeometry: false
includeRelated: true
This works fine except, I want to bring down all of the INSPECTOR records also. Therefore, the queryOptions for INSPECTOR need to look like this:
INSPECTOR :
Query Option: all
useGeometry: false
includeRelated: (ignored since queryOption is all)
Now, I get all of the INSPECTOR records in the replica, but also unintentionally get all of the BUILDING_INSPECTION records that are related to the INSPECTOR records (which ends up being all of the inspections). Furthermore, since the additional BUILDING_INSPECTION records are related to other BUILDING records, I end up unintentionally retrieving all BUILDING records that have an inspection. The issue is that I can't change the query option of BUILDING_INSPECTION to not include related records, because I need the BUILDING_INSPECTION records related to the BUILDING records in the specified envelope.
The way that I understand the createReplica REST endpoint is that there is no way to choose a specific relationship to acknowledge while ignoring all others. Is there something that I am missing here?
