I've created a map with layers to work with ArcGIS Collector App in order for our operators to make edits on there smart phone(Android & ISO) devices while in the field.
Problem: ArcGIS Collector doesn't allow other users to add, edit, or delete features on the map besides the map creator. I tried setting up this process for both ArcGIS Online & Portal. There isn't really any solution on the forums so hopefully someone can lead us in the right direction
ArcGIS Desktop: [Publishing a service] << ==== ArcGIS Online
Parameters:
Properties -----------------------------------------------------------------------------------------------
Maximum number of records returned by the server: 10000
Capabilities:
Tiled Mapping [Unchecked]
Feature Access [Checked]
Feature Access:
Create [Checked]
Delete [Checked]
Query [Checked]
Sync [Checked]
Update [Checked]
Feature Layer (hosted) Settings
Editing
• Who can edit features?
Share the layer to specific groups of people, the organization or publicly via the Share button on the Overview tab. This layer is currently shared with: Organization,
• What kind of editing is allowed?
• What features can editors see?
• What features can editors edit?• What access do anonymous editors (not signed in) have?
• Who can manage edits?
◦ You
◦ Administrators
◦ Data curators with the appropriate privileges
Solution: Users/operators who utilize the published service map should be able to create, edit, and delete features while using the collector app.
