I have two layers with building footprints I need to update one of them. After merging layers I have some features with an sequential number in the field Bld_ID field but some don't. So i need to update the Bld_ID with sequential number and they start with "Bld": example bld000001, bld00002, bld00003, etc. So some how i need to find the last highest sequential number in the field Bld_ID then add 1 to that and use that to update the buildings i have selected.
I have a code i used for something similar but i am running into the an error with this any help would be appreciated:
Runtime error
File "<string>", line 30, in <module>
IndexError: list index out of range
import arcpy, sys, re, os
from arcpy import env
import string
arcpy.env.qualifiedFieldNames = False
Bld = "BuildingFootprints" #target point feature class
BldCount = int(arcpy.GetCount_management(Bld).getOutput(0))
dsc = arcpy.Describe(Bld)
selection_set = dsc.FIDSet
if len(selection_set) == 0:
print "There are no features selected"
elif BldCount >= 1:
#Gets the highest AddressID and calculates new point to assign new highest AddressID
Bld_list = []
with arcpy.da.SearchCursor(Bld, ["Bld_ID"]) as cursor:
for row in cursor:
try:
if "Bld" in row[0]:
Bld_list.append(int(row[0].strip("Bld")))
except TypeError:
pass
del cursor
Bld_list.sort()
Bld_ID = Bld_list[-1] + 1
Bld_ID = 'Bld' + str(Bld_ID)
with arcpy.da.UpdateCursor(Bld, "Bld_ID") as rows:
for row in rows:
row[0] = Bld_ID
rows.updateRow(row)
del row
del rows
