I am new to arcobjects and GIS in general so excuse my noobness. I'm trying to create a console based application that eventually will raster some polygons then do some stats on the rasters but right now I just want to be able to list all the features?(a single attribute from a layer's attribute table) from a given layer/shapefile in an existing mxd. Right now, I can initialize the arc engine, open an mxd, list all the layers within that mxd and open a shapefile from a layer within the mxd.What I need help with is being able to loop through the attribute table for the shapefile I opened from the mxd.Here is the code I have so far:public class EngineTest { @SuppressWarnings("deprecation") public static void main(String[] args) { try { //Step 1: Initialize the Java Componet Object Model (COM) Interop. EngineInitializer.initializeEngine(); //Step 2: Initialize a valid license. new AoInitialize().initialize (esriLicenseProductCode.esriLicenseProductCodeEngine); //Step 3 : Invoke ArcObjects. MapDocument mapDocument = new MapDocument(); if (mapDocument.isPresent("D:\\Tellus_Sedimentary_Basin.mxd")) { mapDocument.open("D:\\Tellus_Sedimentary_Basin.mxd",""); mapDocument.setAuthor("Brian Varela"); IMap main_map = mapDocument.getMap(0); IFeatureLayer layer = (IFeatureLayer) main_map.getLayer(0); IFeatureClass classLayer = layer.getFeatureClass(); IDataLayer2 dataLayer = (IDataLayer2) layer; IDatasetName name = (IDatasetName) dataLayer.getDataSourceName(); IWorkspaceName workspace = name.getWorkspaceName(); ListLayers((Map)mapDocument.getMap(0)); System.out.println("Layer "+layer.getName()+" located at "+workspace.getPathName()+" "+layer.getDisplayField()); } } catch (IOException ex) { System.out.println(ex.getMessage()); System.out.println("App failed."); } finally { try { //Step 4: Release the license. new AoInitialize().shutdown(); System.out.println("License released!"); } catch (IOException ex) { ex.printStackTrace(); } } } //End of method main. public static void ListLayers(com.esri.arcgis.carto.Map map) { try{ for(int i=0; i<map.getLayerCount(); i++) { System.out.println("Layer "+i+". "+map.getLayer(i).getName()); } }catch(AutomationException ae) { ae.printStackTrace(); }catch(IOException e) { e.printStackTrace(); } } } //End of class
