I have created an extension Add In that should start listening to editor events when it is checked on. Everything is working great if the extension is not checked on startup. I check the extension on and everything works as expected. The problem is when I leave the extension checked on. When I reopen the map, I see my message boxes on startup, but the editor listeners do not work. This is an autoload extension not a Just In Time (JIT) so autoload is set to true in my config file.
I have searched every example and help topic I can find and am stumped. Any help would be appreciated!
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.Editor
Imports ESRI.ArcGIS.Desktop.AddIns
Imports ESRI.ArcGIS.Geodatabase
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.Framework
Public Class Default_GDRC_Num_ext
Inherits ESRI.ArcGIS.Desktop.AddIns.Extension
Public Sub New()
End Sub
Private Shared s_Extension As Default_Num_ext
Protected Overrides Sub OnStartup()
s_Extension = Me
Initialize()
End Sub
Protected Overrides Function OnSetState(ByVal state As ESRI.ArcGIS.Desktop.AddIns.ExtensionState) As Boolean
Me.State = state
If state = ESRI.ArcGIS.Desktop.AddIns.ExtensionState.Enabled Then
MsgBox("Enabled text")
Initialize()
AddHandler Events.OnStartEditing, AddressOf Events_OnStartEditing
AddHandler Events.OnStopEditing, AddressOf Events_OnStopEditing
Else
MsgBox("Not Enabled text")
Uninitialize()
End If
Return MyBase.OnSetState(state)
End Function
Protected Overrides Function OnGetState() As ESRI.ArcGIS.Desktop.AddIns.ExtensionState
Return Me.State
End Function
Private Sub Initialize()
If Me.State <> ExtensionState.Enabled Then
Return
End If
MsgBox("Initializing")
End Sub
Private Sub Uninitialize()
If s_Extension Is Nothing Then
Return
End If
MsgBox("Uninitializing")
RemoveHandler Events.OnStartEditing, AddressOf Events_OnStartEditing
End Sub
Private ReadOnly Property MyEditor() As IEditor
Get
Dim m_editor As IEditor
Dim editorUid As New UID()
editorUid.Value = "esriEditor.Editor"
m_editor = TryCast(My.ArcMap.Application.FindExtensionByCLSID(editorUid), IEditor)
Return TryCast(m_editor, IEditor)
End Get
End Property
Private ReadOnly Property Events() As IEditEvents_Event
Get
Dim m_editorEvents As IEditEvents_Event = TryCast(MyEditor, IEditEvents_Event)
Return TryCast(m_editorEvents, IEditEvents_Event)
End Get
End Property
Private Sub Events_OnStartEditing()
MsgBox("you are now editing")
End Sub
Private Sub Events_OnStopEditing()
MsgBox("You will stop editing")
End Sub
Protected Overrides Sub OnShutdown()
s_Extension = Nothing
Uninitialize()
End Sub<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
