I have a IfeatureCursor that I initialized to null. When I try to set it with a IfeatsureSelection.SelectionSet.Search(,,out IfetureCursor) I get an error saying
cannot convert 'out ESRI.ArcGIS.Geodatabase.IFeatureCursor' to 'out ESRI.ArcGIS.Geodatabase.ICursor'
Code
void SelectionChangedFunc()
IFeatureSelection featSel = default(IFeatureSelection); //link to a feature selection
IFeatureCursor selCur = null; //feature cursor to iterate
IFeature f = default(IFeature); //link to a feature
featSel = p_addressLayer as IFeatureSelection;
MessageBox.Show("changed"); //debugging purposes
if (featSel.SelectionSet.Count > 0)
featSel.SelectionSet.Search(null, false, out selCur);
f = selCur.NextRow();
MessageBox.Show(f.Fields.FindField("STR_NAME").ToString()); //debugging purposes
MessageBox.Show(selCur.Fields.FindField("STR_NAME").ToString()); //debugging purposes
}Line 15 is where the issue is. I tried casting with no luck. Anyone come accross this issue or was able to successfully use a IfeatureCursor in C# SDK 10.4
