For some time now I have been using Pro and have often wondered why two geodatabases are created for every Pro project. If I create a new project, Pro will create a geodabase with the name of my project and use this as the current and scratch workspace (I have accepted these defaults under Project > Options). It will also create a map.gdb file in same folder.
If I use map notes, then these too are saved to the current project geodatabase. So what then is the role and purpose of the map.gdb that is created? I dont have a problem with it, just curious and want to understand why it is happening. There does not appear to be a help topic that addresses this, hence I am reaching out to this community. Any ideas?
