I am new to python and I am using python script for unziping shape file and append the unzip shape file's records to an existing shape file. The two shape files have a different field structure.So I am using "schemaType" as "NO_TEST".The unzip part code works fine but the append part code keeps sending an error:ERROR 999999: Error executing function. Failed to execute (Append).
Could you anyone can help me what I am doing wrong?I am using ArcGIS 10.1 version for SDE and Server.Here is my code:import sys, zipfile, arcpy, urllib2, os, traceback from os.path import isdir, join, normpath, split from arcpy import env env.workspace = "E:\\test\\SMCS\\test\\test" #Set local variables tempshape = "tempshape.shp" schemaType = "NO_TEST" fieldMappings = "Join" subtype = "" #Connect to the target SDE targetSDE_test = "Database Connections\\sde@test@test.sde\\test.sde.SMCS_SDE_TEST2" # Function to unzipping the contents of the zip file # def unzip(path, zip): # If the output location does not yet exist, create it # if not isdir(path): os.makedirs(path) for each in zip.namelist(): arcpy.AddMessage("Extracting " + os.path.basename(each) + " ...") # Check to see if the item was written to the zip file with an # archive name that includes a parent directory. If it does, create # the parent folder in the output workspace and then write the file, # otherwise, just write the file to the workspace. # if not each.endswith('/'): root, name = split(each) directory = normpath(join(path, root)) if not isdir(directory): os.makedirs(directory) file(join(directory, name), 'wb').write(zip.read(each)) if __name__ == '__main__': try: # Get the tool parameter values # infile = "E:\\test\\test\\test\\test.zip" print infile ###outfol: need to be changed the location to the temp folder in the server outfol = "E:\\test\\test\\test\\test" print outfol # Create the zipfile handle for reading and unzip ittargetSDE_SMCS # zip = zipfile.ZipFile(infile, 'r') unzip(outfol, zip) zip.close() except: # Return any Python specific errors and any error returned by the geoprocessor # tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n " + \ str(sys.exc_type)+ ": " + str(sys.exc_value) + "\n" arcpy.AddError(pymsg) msgs = "GP ERRORS:\n" + arcpy.GetMessages(2) + "\n" arcpy.AddError(msgs) try: # All polygon FCs in the workspace are MA town shapefiles, we want to append these to the empty FC fcList = arcpy.ListFeatureClasses("","POLYGON") for fc in fcList: print str(fc) #process: Append new record arcpy.Append_management(fcList, targetSDE_test, schemaType, fieldMappings, subtype) except: #if an error occured while runing a tool print the message print arcpy.GetMessages()Cheers,SH
