Hi All,
I have seen Robert Scheitlin, GISP solution on below link and tried the same using WAB 2.15 but all the fields are getting downloaded in my csv.
Web App Builder - How to limit fields in "export to CSV" option in query widget?
I have tried below code:
<SPAN class="keyword token">var</SPAN> resultfields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>i<SPAN class="operator token">=</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token"><</SPAN> popupInfos<SPAN class="punctuation token">.</SPAN>length<SPAN class="number token">-1</SPAN><SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>popupInfos<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>visible <SPAN class="operator token">==</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
resultfields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>popupInfos<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>fieldName<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">var</SPAN> fFlds <SPAN class="operator token">=</SPAN> array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">filter</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>fldInfo<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> resultfields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>fldInfo<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> featureSet <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureSet</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
featureSet<SPAN class="punctuation token">.</SPAN>fields <SPAN class="operator token">=</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clone</SPAN><SPAN class="punctuation token">(</SPAN>fFlds<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Please help.
Krish
