I have a Python script that I would like to operate as a standalone script. When I copy and paste it into the Python window in a fresh ArcMap .mxd, it operates fine. However, when I attempt to run it as a standalone script within my Python IDE, it fails during the tabulate area tool that is written like this:
tab_area = TabulateArea(target_features,"unique_id",sdm,"Value",os.path.join(outTable,"tab_area_temp"),"30")
I am getting the ambiguous 999998 error message:
ExecuteError: ERROR 999998: Unexpected Error.
Does anyone have any ideas as to why this might be working fine when copied and pasted into the Python window in ArcMap, but failing as a standalone script?
Full Python script is below for reference:
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> os<SPAN class="punctuation token">,</SPAN> datetime
<SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env
<SPAN class="keyword token">from</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>sa <SPAN class="keyword token">import</SPAN> <SPAN class="operator token">*</SPAN>
<SPAN class="keyword token">from</SPAN> itertools <SPAN class="keyword token">import</SPAN> groupby
<SPAN class="keyword token">from</SPAN> operator <SPAN class="keyword token">import</SPAN> itemgetter
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"start time: "</SPAN> <SPAN class="operator token">+</SPAN> datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>now<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>strftime<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"%Y-%m-%d %H:%M:%S"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
target_features <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\Users\mmoore\Documents\ArcGIS\COA.gdb\PlanningUnit_Hex10acre'</SPAN>
sdm_folder <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\Users\mmoore\Documents\ArcGIS\SDMs.gdb'</SPAN>
outTable <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\Users\mmoore\Documents\ArcGIS\out_tables.gdb'</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> sdm_folder
sdms <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListRasters<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
species_tables <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> sdm <SPAN class="keyword token">in</SPAN> sdms<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> sdm <SPAN class="operator token">+</SPAN> <SPAN class="string token">" started at: "</SPAN> <SPAN class="operator token">+</SPAN> datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>now<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>strftime<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"%Y-%m-%d %H:%M:%S"</SPAN><SPAN class="punctuation token">)</SPAN>
sdm_path <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>sdm_folder<SPAN class="punctuation token">,</SPAN>sdm<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CheckOutExtension<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Spatial"</SPAN><SPAN class="punctuation token">)</SPAN>
tab_area <SPAN class="operator token">=</SPAN> TabulateArea<SPAN class="punctuation token">(</SPAN>target_features<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"unique_id"</SPAN><SPAN class="punctuation token">,</SPAN>sdm<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Value"</SPAN><SPAN class="punctuation token">,</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>outTable<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"tab_area_temp"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"30"</SPAN><SPAN class="punctuation token">)</SPAN>
sdm_table <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>TransposeFields_management<SPAN class="punctuation token">(</SPAN>tab_area<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"VALUE_1 Low;VALUE_2 Medium"</SPAN><SPAN class="punctuation token">,</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>outTable<SPAN class="punctuation token">,</SPAN>sdm<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"OccProb"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"PERCENTAGE"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"unique_id"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>sdm_table<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"ElSeason"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">20</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"ElSeason"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>sdm_table<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"OccProb"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"PERCENTAGE"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"ElSeason"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">40468.383184</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">*</SPAN><SPAN class="number token">100</SPAN>
cursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN>
row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> sdm
<SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="string token">"VALUE_1"</SPAN><SPAN class="punctuation token">:</SPAN>
row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Low"</SPAN>
<SPAN class="keyword token">elif</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="string token">"VALUE_2"</SPAN><SPAN class="punctuation token">:</SPAN>
row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Medium"</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>sdm_table<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"PERCENTAGE"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">></SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">pass</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
cursor<SPAN class="punctuation token">.</SPAN>deleteRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
case_fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"unique_id"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ElSeason"</SPAN><SPAN class="punctuation token">]</SPAN>
max_field <SPAN class="operator token">=</SPAN> <SPAN class="string token">"PERCENTAGE"</SPAN>
sql_orderby <SPAN class="operator token">=</SPAN> <SPAN class="string token">"ORDER BY {}, {} DESC"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="string token">","</SPAN><SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>case_fields<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> max_field<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># use groupby cursor to order by percent coverage</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>sdm_table<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">,</SPAN> sql_clause<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">(</SPAN>None<SPAN class="punctuation token">,</SPAN> sql_orderby<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
case_func <SPAN class="operator token">=</SPAN> itemgetter<SPAN class="punctuation token">(</SPAN><SPAN class="operator token">*</SPAN><SPAN class="punctuation token">(</SPAN>cursor<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">.</SPAN>index<SPAN class="punctuation token">(</SPAN>fld<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> fld <SPAN class="keyword token">in</SPAN> case_fields<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> key<SPAN class="punctuation token">,</SPAN> group <SPAN class="keyword token">in</SPAN> groupby<SPAN class="punctuation token">(</SPAN>cursor<SPAN class="punctuation token">,</SPAN> case_func<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
next<SPAN class="punctuation token">(</SPAN>group<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> extra <SPAN class="keyword token">in</SPAN> group<SPAN class="punctuation token">:</SPAN>
species_tables<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>sdm_table<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>tab_area<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> sdm <SPAN class="operator token">+</SPAN> <SPAN class="string token">" finished at: "</SPAN> <SPAN class="operator token">+</SPAN> datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>now<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>strftime<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"%Y-%m-%d %H:%M:%S"</SPAN><SPAN class="punctuation token">)</SPAN>
merge <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Merge_management<SPAN class="punctuation token">(</SPAN>species_tables<SPAN class="punctuation token">,</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>outTable<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SGCN_SDMxPU"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"end time: "</SPAN> <SPAN class="operator token">+</SPAN> datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>now<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>strftime<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"%Y-%m-%d %H:%M:%S"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The full error message is as follows:
File "H:\Scripts\COA\COA\COA_species_populator v.7_SDMraster.py", line 23, in <module>
tab_area = TabulateArea(target_features,"unique_id",sdm,"Value",os.path.join(outTable,"tab_area_temp"),30)
File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\sa\Functions.py", line 6183, in TabulateArea
processing_cell_size)
File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\sa\Utils.py", line 53, in swapper
result = wrapper(*args, **kwargs)
File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\sa\Functions.py", line 6175, in Wrapper
File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\geoprocessing\_base.py", line 510, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
Failed to execute (TabulateArea).<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
