Combining a drivetime and identify widget.
Hello everyone. I recently began playing with flex and I am trying to accomplish a task I think should be straight forward but am having some difficulty with. I am trying to create a widget which calculates a drive time, and returns an identify on the objects in the returned drive time.
I can add a button to the identify widget, which when click looks for a map click and calculates a drive time. Now, when a drive time is calculated using the first shown function, is the
variable FeatureSet a geometry variable that I can feed into the second identify features function?
Will that be enough to get this tool working? Any other advice on how it could or should be done?
Sorry about the vague question, but I am getting going and having some trouble with this one.
[PHP]
private function computeServiceArea(mapPoint:MapPoint):void
myGraphicsLayer.clear();
var graphic:Graphic = new Graphic(mapPoint, sms_circleAlphaSizeOutline);
myGraphicsLayer.add(graphic);
var featureSet:FeatureSet = new FeatureSet([ graphic ]);
var params:Object =
"Input_Location": featureSet,
"Drive_Times": driveTimes
gp.execute(params, new AsyncResponder(onResult, onFault));
function onResult(gpResult:ExecuteResult,token:Object = null):void
var pv:ParameterValue = gpResult.results[0];
var fs:FeatureSet = pv.value as FeatureSet;
myGraphicsLayer.graphicProvider = fs.features;
myGraphicsLayer.renderer=uniqueValueRenderer;
function onFault(info:Object, token:Object = null):void
Alert.show(info.toString());
[/PHP]
[PHP]
//identify features
private function identifyFeatures(geom:Geometry):void
var identifyParams:IdentifyParameters = new IdentifyParameters();
identifyParams.returnGeometry = returnGeomForZoom;
identifyParams.tolerance = identifyTolerance;
identifyParams.geometry = geom;
identifyParams.width = map.width;
identifyParams.height = map.height;
identifyParams.mapExtent = map.extent;
identifyParams.spatialReference = map.spatialReference;
if(betaReturnGeometryFix){
var geomString:String = JSON.encode(geom).replace(',"spatialReference":{"wkid":' + geom.spatialReference.wkid + '}','');
var idURL:String = "?geometryType=" + geom.type + "&geometry=" + geomString;
idURL += "&sr=" + map.spatialReference.wkid.toString() + "&layers="
var idURL2:String = "&tolerance=" + identifyTolerance.toString() + "&mapExtent=" + map.extent.xmin.toString() + "," + map.extent.ymin.toString() + "," + map.extent.xmax.toString() + "," + map.extent.ymax.toString();
idURL2 += "&imageDisplay=" + map.width.toString() + "," + map.height.toString() + ",96" + "&returnGeometry=" + returnGeomForZoom.valueOf().toString() + "&f=json";
for (var i:Number = map.layerIds.length -1; i >= 0; i--)
identifyParams.layerOption = identifyLayerOption;
var layer:Layer = map.getLayer(map.layerIds);
identifyParams.layerIds = null;
var url:String = "";
//HAB:Does this layer require a proxy???
var useProxy:Boolean = false;
//HAB:loop thru proxy layer list and determine which layer needs a proxy
for(var p:int=0; p<configIdentProxyLayers.length; p++)
//HAB:set the proxy flag if needed
if (layer.name == configIdentProxyLayers.name)
useProxy = true;
if (layer is ArcGISDynamicMapServiceLayer)
var dynamicLayer:ArcGISDynamicMapServiceLayer = layer as ArcGISDynamicMapServiceLayer;
url = dynamicLayer.url;
if(identifyLayerOption == "visible")
if(dynamicLayer.visible == false){
url="";
}else{
if(dynamicLayer.visibleLayers){
identifyParams.layerIds = new Array();
for (var j:Number = 0; j < dynamicLayer.visibleLayers.source.length; j++)
if (dynamicLayer.layerInfos[dynamicLayer.visibleLayers.source] &&
!dynamicLayer.layerInfos[dynamicLayer.visibleLayers.source].subLayerIds)
identifyParams.layerIds.push(dynamicLayer.visibleLayers.source);
identifyParams.layerOption = "all";
else if (layer is ArcGISTiledMapServiceLayer)
var tiledLayer:ArcGISTiledMapServiceLayer = layer as ArcGISTiledMapServiceLayer;
url = tiledLayer.url;
if(tiledLayer.visible == false)
url="";
else if (layer is FeatureLayer)
var featLayer:FeatureLayer = layer as FeatureLayer;
url = featLayer.url;
var layId:int = -1;
var arcDL:ArcGISDynamicMapServiceLayer;
if( url.indexOf("FeatureServer") > -1)
var msName:String = url.replace("FeatureServer","MapServer");
arcDL = new ArcGISDynamicMapServiceLayer(msName.substring(0,msName.lastIndexOf("/")));
url = arcDL.url;
layId = parseInt(msName.substring(msName.lastIndexOf("/")+ 1));
}else{
arcDL = new ArcGISDynamicMapServiceLayer(url.substring(0,url.lastIndexOf("/")));
layId = parseInt(url.substring(url.lastIndexOf("/")+ 1));
url = arcDL.url;
if(layId != -1)
identifyParams.layerIds = [layId];
if(featLayer.visible == false)
url="";
if(url)
var visString:String = "";
if(identifyParams.layerIds){
visString += ":";
for(var v:int=0; v<identifyParams.layerIds.length; v++)
if(v>0)
visString += ","
visString += identifyParams.layerIds.toString();
var cIdURL:String = url + "/identify" + idURL + identifyLayerOption + visString + idURL2;
var iService:HTTPService = new HTTPService();
iService.url = cIdURL;
iService.resultFormat = "text";
iService.addEventListener(ResultEvent.RESULT, buildIdResults);
iService.addEventListener(FaultEvent.FAULT, onFault);
iService.send();
}else{
var identifyTask:IdentifyTask = new IdentifyTask(url);
//HAB:apply proxy if needed
if(useProxy)identifyTask.proxyURL = proxyURL;
identifyTask.addEventListener(IdentifyEvent.EXECUTE_COMPLETE, onResult);
identifyTask.addEventListener(FaultEvent.FAULT, onFault);
identifyTask.execute(identifyParams);
showMessage(loadingLabel, true);
showStateResults();
private function buildIdResults(event:ResultEvent):void
var rawData:String = String(event.result);
var data:Object = JSON.decode(rawData);
var retArray:Array = [];
if(data.error){
//do nothing;
}else{
for each( var idObj:Object in data.results)
var idResult:IdentifyResult = new IdentifyResult();
idResult.displayFieldName = idObj.displayFieldName;
idResult.layerId = idObj.layerId;
idResult.layerName = idObj.layerName;
idResult.feature = buildGra(idObj);
retArray.push(idResult);
function buildGra(obj:Object):Graphic
var gra:Graphic;
switch(obj.geometryType)
case Geometry.MAPPOINT:
var mp:MapPoint = new MapPoint(obj.geometry.x, obj.geometry.y, new SpatialReference(obj.geometry.spatialReference.wkid));
gra = new Graphic(mp);
gra.attributes = obj.attributes;
break;
case Geometry.POLYGON:
var mPoly:Polygon = new Polygon(null);
for (var i2:int = obj.geometry.rings.length - 1; i2 >= 0; i2--)
var ringArray:Array = [];
for (var j1:int = 0; j1 < obj.geometry.rings[i2].length; j1++)
var mpStr:String = obj.geometry.rings[i2][j1];
var xyArr:Array = mpStr.split(",")
var mp2:MapPoint = new MapPoint(xyArr[0], xyArr[1]);
mp2.spatialReference = new SpatialReference(obj.geometry.spatialReference.wkid);
ringArray.push(mp2);
mPoly.addRing(ringArray);
mPoly.spatialReference = new SpatialReference(obj.geometry.spatialReference.wkid);
gra = new Graphic(mPoly);
break;
case Geometry.EXTENT:
var ext:Extent = new Extent(obj.geometry.xmin, obj.geometry.ymin, obj.geometry.xmax, obj.geometry.ymax, new SpatialReference(obj.geometry.spatialReference.wkid));
gra = new Graphic(ext);
break;
case Geometry.POLYLINE:
var pLine:Polyline = new Polyline(obj.Geometry.paths, new SpatialReference(obj.geometry.spatialReference.wkid));
gra = new Graphic(pLine);
break;
return gra;
onResult(new IdentifyEvent("",retArray));
[/PHP]
