I thought a found a slick way to compare on a number in a string field.
CAST(SoilDepthLower AS INTEGER) < 70
This works in a ArcMap definition query just fine.
But when I try to use it in a SearchCursor Query it says Invalid SQL Statement.
whereClause = "CAST(SoilDepthLower AS INTEGER) < 70"
keyField1 = arcpy.ListFields(tableLayer)[1].name
keyField2 = arcpy.ListFields(tableLayer)[2].name
fieldList = ["SoilDepthLower", keyField1, keyField2]
with arcpy.da.SearchCursor(tableLayer, fieldList, whereClause) as cursor:
I have tried smallint, double, etc - using both uppercase and lower case.
This help page says it is supported http://pro.arcgis.com/en/pro-app/help/mapping/navigation/sql-reference-for-elements-used-in-query-expressions.htm
What is the issue?
