Hi all -
I'm using the Robert's eSearch widget v. 3.6.8.
I have a feature class with a joined table. Whenever I use the eSearch widget the maximum number of records (n=1000) is returned as if it's selecting everything in the feature class. I know it should only return 3 records based on my search criteria.
The field names in the .xml are set correctly based on the REST service between the two tables:
- Special_Status_Plants_info.SCI_NAME ( type: esriFieldTypeString , alias: SCI_NAME , length: 64 )
- Special_Status_Plants.PARK_CODE ( type: esriFieldTypeString , alias: PARK_CODE , length: 8 )
The only difference between this feature class and others that are working correctly in the same service is the join.
Any ideas if this is a bug? I'm having trouble navigating the GeoNet site to look around.... And actually - anyone have a beginners guide to how to even use the GeoNet site!?
Many thanks,
Meg
