Having Maximum Number of Records Returned by Server set to 1000 on ArcGIS Server - Feature Service as
How can I force the Returned Records to be on current extent of viewDiv
<SPAN class="keyword token">var</SPAN> layer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"961a56d51afa42df9acsd88b8a7e01b13f"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
definitionExpression<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Building Footprints"</SPAN><SPAN class="punctuation token">,</SPAN>
minScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">72223.819286</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"4f2e99ba65e34asbb8af4d33d9778fb8e"</SPAN>
layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>layer<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">123.110722</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">49.249793</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">14</SPAN><SPAN class="punctuation token">,</SPAN>
constraints<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
snapToZoom<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
resizeAlign<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"top-left"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Right now what is happening is 1000 recorded are returning to the map regardless of extent view so I have lots of Gaps on the basemap and feature service overlay while there some records loaded to map which are not in the view port
