I’m interested in creating a custom widget for a work flow that our teams do constantly. I am a bit new to development side and wanted to get one someone’s opinion that has experience in this field. This is what I want the tool to accomplish.
- A user can click anywhere on the map and have a layer created that shows an analysis of the parcels (land owners) in the area.
- Here are the geoprocesses the tool needs to do:
- Select all the parcels (layer) within X amount of miles (user input) from where the user clicks on the map
- Then it dissolves the parcels layer by the owner name and sums up the acreage field.
- Displays the new parcels that are dissolved on the map by a choropleth (heat) map style based on the acreage sum field.
- Have it display the results (attribute table) on the side. Option to export the data, or to click again and do the same process over again.
- We are currently using AGOL and will be using Portal in the future.
So my questions are:
- Will this workflow be able to be accomplished with a custom widget.
If so, can this be done in AGOL and Portal or both.
- And is this the most effective way about doing this; creating a custom widget app.
Thanks in advance and I hope someone can help me and point me to the right direction to get this done.#
