I am trying to modify the WebTileLayer 3d example (WebTileLayer 3D | ArcGIS API for JavaScript 4.1) to use the tiles at this address:
http://tiles.gina.alaska.edu/tiles/SPOT5.SDMI.ORTHO_RGB/tile/{x}/{y}/{z}.png
and I end up with the code below but the tiles never get loaded. They load just fine in a Cesium web globe app so I know they should work. Can anyone help me troubleshoot this?
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>WebTileLayer 3D - 4.1</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.1/esri/css/main.css">
<script src="https://js.arcgis.com/4.1/"></script>
<script>
require([
"esri/config",
"esri/layers/WebTileLayer",
"esri/Map",
"esri/views/SceneView",
"dojo/dom",
"dojo/domReady!"
], function(esriConfig, WebTileLayer, Map, SceneView, dom) {
esriConfig.request.corsEnabledServers
.push("a.tile.stamen.com", "b.tile.stamen.com", "c.tile.stamen.com",
"d.tile.stamen.com");
var map = new Map({
ground: "world-elevation"
var view = new SceneView({
container: "viewDiv",
map: map,
scale: 10000000,
center: [-154, 62]
var tiledLayer = new WebTileLayer({
urlTemplate: "http://tiles.gina.alaska.edu/tiles/SPOT5.SDMI.ORTHO_RGB/tile/{col}/{row}/{level}.png",
map.add(tiledLayer);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
