Hi -
Does anyone know why Pro 2.0.1 would drop my signed-in status to our AGOL org? Is there a time-out setting somewhere? The way I am staging and uploading hosted content relies on my being signed into our AGOL account:
arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>CreateWebLayerSDDraft<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"V:/ArcProProjets/AgolUpdates/Cadastral/"</SPAN> <SPAN class="operator token">+</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">+</SPAN> <SPAN class="string token">".sddraft"</SPAN><SPAN class="punctuation token">,</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"MY_HOSTED_SERVICES"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"FEATURE_ACCESS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"OpenData"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Cadastral'</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>StageService_server<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'V:/ArcProProjets/AgolUpdates/Cadastral/'</SPAN> <SPAN class="operator token">+</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">+</SPAN> <SPAN class="string token">'.sddraft'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'V:/ArcProProjets/AgolUpdates/Cadastral/'</SPAN> <SPAN class="operator token">+</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">+</SPAN> <SPAN class="string token">'.sd'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I'm running this once a week on Saturdays. I should note that we are using our concurrent license manager and not named user accounts.
David
