We're running ArcGIS Enterprise 10.6 with Portal, Data Store and hosting server all on separate machines.
I've published a hosted feature service from ArcMap containing two empty point layers, both with attachments enabled. The content page for the item in Portal reports the size as 55kb (which it probably was when I published it) and if I use the python api to report the size using gis.content.get(itemid).size then it reports 56560 (which I assume is in bytes).
However this layer has had a lot of records inserted into it recently using Collector, including multiple photos as attachments for each layer. If I export the service to a file geodatabase then the reported size of that item is over 750mb, which is a truer reflection of the size of my feature service.
I get that the data is actually hidden away in the Data Store but is there a way to force Portal to properly report on the true size of the layer as stored? Either using the Python API or Rest admin interface?
I'd like to get to a point where I can script a report on the whole Portal to show the top items that account for space in the Data Store.
Gareth
