I did posted a similar question earlier, but it seems I can't delete that one. I there presented code with a couple of other issues. I'm using the PrintTask() function from the ArcGIS Online API. Works like a charm...untill you add your own graphics.When I don't run the addedAskedSymbolsToMap function in the code below, and only have one feature layer, then the print is perfectly created. When I do run it, i'm adding custom symbols. The console shows the following error:"Error performing execute operation"What's the deal with custom graphics and PrintTask, how should I adjust the code below to something that's okay with the PrintTask function?Here's the code:dojo.require("dijit.dijit"); // optimize: load dijit layer
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.graphic");
dojo.require("esri.symbol");
dojo.require("esri.layers.FeatureLayer");
dojo.require("dijit.layout.TabContainer");
dojo.require("esri.tasks.query");
dojo.require("esri.dijit.Print");
dojo.require("esri.tasks.PrintTask");
var map;
var testedArea = 'nederland';
var basemapUrl = "http://tiles.arcgis.com/tiles/nSZVuSZjHpEZZbRo/arcgis/rest/services/Topografie_in_de_klas_"+testedArea+"_ondergrond/MapServer";
var featureLayerUrl = "http://services.arcgis.com/nSZVuSZjHpEZZbRo/ArcGIS/rest/services/Topografie_in_de_klas_"+testedArea+"/FeatureServer/0";
var printUrl = "http://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task";
function init(){
esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
var initialExtent = new esri.geometry.Extent({"xmin":127181.62867976735,"ymin":6618002.046143801,"xmax":1141291.3011197727,"ymax":7298584.615330108,"spatialReference":{"wkid":102100}});
map = new esri.Map("map", {
extent: initialExtent,
//zoom: 2
dojo.connect(map, "onLoad", doQueries);
//dojo.connect(map, "onLoad", createPrint);
map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer(basemapUrl));
function doQueries(){
content = 'Cito100_onderdeel=1';
queryContentSelect = new esri.tasks.Query();
queryContentSelect.returnGeometry = true;
queryContentSelect.outFields = ["Type", "NAME"];
queryContentSelect.where = content;
var featureLayer = new esri.layers.FeatureLayer(featureLayerUrl,{
mode: esri.layers.FeatureLayer.MODE_SELECTION,
outFields: ["*"]
map.addLayer(featureLayer);
//featureLayer.clearSelection();
featureLayer.selectFeatures(queryContentSelect, esri.layers.FeatureLayer.SELECTION_NEW);
//Set the content of the graphicsLayer selection
var queryGraphicsTask = new esri.tasks.QueryTask(featureLayerUrl);
var queryGraphicsSelect = new esri.tasks.Query();
queryGraphicsSelect.returnGeometry = true;
queryGraphicsSelect.outFields = ["Type", "NAME"];
queryGraphicsSelect.objectIds = [1,12,14,15,24,25,89, 20];
queryGraphicsTask.execute(queryGraphicsSelect, addAskedSymbolsToMap);
function addAskedSymbolsToMap(featureSet){
var graphicsLayer = new esri.layers.GraphicsLayer();
map.addLayer(graphicsLayer);
//Add asked places to the graphics layer
var i =1;
dojo.forEach(featureSet.features, function(feature) {
if(feature.attributes.Type == 'Gebied'){
iconSymbolNumbered = new esri.symbol.PictureMarkerSymbol({
"url":"http://tpgrf.nl/testserver/alpha/wp-content/themes/topografieindeklas/style/img/toetsNumberIcons/icon-"+feature.attributes.Type+"-"+i+".jpg",
'width':24,
'height':24,
'xoffset':0,
'yoffset': 0});
}else{
"url":"http://tpgrf.nl/testserver/alpha/wp-content/themes/topografieindeklas/style/img/toetsNumberIcons/red/NumberIcon"+i+".png",
'width':15,
'height':20,
'xoffset':0,
'yoffset': 10});
var graphic = new esri.Graphic(feature.toJson());
graphic.setSymbol(iconSymbolNumbered);
graphicsLayer.add(graphic);
//map.graphics.add(graphic);
i++;
createPrint();
function createPrint(){
//Set up print stuff
var printTask = new esri.tasks.PrintTask(printUrl);
var params = new esri.tasks.PrintParameters();
var template = new esri.tasks.PrintTemplate();
params.map = map;
template.exportOptions = {
width: 595,
height: 842,
dpi: 96
template.layout = "MAP_ONLY";
template.preserveScale = false;
params.template = template;
//dojo.connect(map, "onLoad", function() {//Fire the print task
//printTask.execute(params, printResult, printError);
setTimeout(function(){printTask.execute(params, printResult, printError);},2500);
function printResult(result){
console.log(result.url)
function printError(result){
console.log(result);
dojo.addOnLoad(init);
