Hi all,I'm at the very early learning stages of python, so please don't bite 😮I have the following code import arcgisscripting
gp = arcgisscripting.create(9.3)
print "Tools imported"
gp.workspace = "C:/Temp"
print "Workspace set"
gp.overwriteoutput = 1
print "Overwrite set"
Input = "COVER63p.shp"
Output = "no_damage.shp"
Erase = "special_regions.shp"
print "variables set"
gp.erase_analysis(Input, Erase, Output)
print "tool has run...success"
print gp.messages()
Which should work, however when i run it in pythonwin (it takes about 15 minutes???) but also outputs this error in the interactive window.>>> Tools importedWorkspace setOverwrite setvariables settool has run...successTraceback (most recent call last): File "C:\Python25\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 325, in RunScript   exec codeObject in __main__.__dict__ File "Z:\Data\Halil\Halil\ArcGIS\Python\Python\Homework\Erase.py", line 23, in <module>   print gp.messages()AttributeError: Object: Tool or environment <messages> not found>>> Can someone explain what it means because I haven't a clue.Cheershalil
