I have a script that adds .lyr files to an MXD.A loop then iterates through the layers in the MXD and turns them all OFF, using the lyr.visible = False function. This part of my code works.I then want to iterate through the list again, turn on the first layer, export the map as a PDF, turn off the layer, then move onto the next layer. This is the part that doesn't work. The layers do not turn on again. The PDFs export, but they are all blank.I've seen this question asked before, but the solutions listed don't seem to be working for me. I've posted the code below.LYR_list_MXD = arcpy.mapping.ListLayers(MXD,"*_env*",DF) for LYR in LYR_list_MXD: LYR.visible = False MXD.save() # Turn on each layer individually and export map as new PDF for LYR in LYR_list_MXD: LYR.visible = True output_PDF = OutputPDFFolder + "\\" + str(LYR) + ".pdf" arcpy.mapping.ExportToPDF(MXD, output_PDF) LYR.visible = False MXD.save()
Any suggestions would be greatly appreciated.Thanks-Zack
