I am trying to create a service in a folder called Mobile_Services.When I publish a map using ArcMap or ArcCatalog I am able to select an Existing folder called "Mobile_Services".But when I use the code below, the location of the service appears into the root directory of the server, which is the default as mentioned in the help files.I would like to have the service created in an existing folder called "Mobile_Services". Please have a look at my code and hope fully someone can shed some light on this. public static void PublishMobileMapServiceForRaDCAMS(string serverMachineName, string serviceName, string pathToMXD) { //define paths for the onlineresource property in the extension properties string resourceWMS = "http://" + serverMachineName + "/ArcGIS/services/" + serviceName + "/MapServer/WMSServer"; string resourceMobile = "http://" + serverMachineName + "/ArcGIS/services/" + serviceName + "/MapServer/MobileServer"; // Connect to the ArcGIS server called serverMachineName (string) . IGISServerConnection pGISServerConnection = new GISServerConnectionClass(); pGISServerConnection.Connect(serverMachineName); // create the new configuration IServerObjectAdmin4 pServerObjectAdmin = (IServerObjectAdmin4)pGISServerConnection.ServerObjectAdmin; IServerObjectConfiguration pConfiguration = pServerObjectAdmin.CreateConfiguration(); IServerObjectConfiguration2 pConfiguration2 = (IServerObjectConfiguration2)pConfiguration; IServerObjectConfiguration3 pConfiguration3 = (IServerObjectConfiguration3)pConfiguration; // set the General Configuration Settings pConfiguration.Name = serviceName; // the name of this configuration pConfiguration.TypeName = "MapServer"; // the type of server object to be created pConfiguration.IsPooled = true; pConfiguration.MinInstances = 1; pConfiguration.MaxInstances = 2; pConfiguration.WaitTimeout = 60; pConfiguration.UsageTimeout = 600; pConfiguration.StartupType = esriStartupType.esriSTAutomatic; pConfiguration.IsolationLevel = esriServerIsolationLevel.esriServerIsolationHigh; //IEnumServerDirectory pEnumServerDirectories = pServerObjectAdmin.GetServerDirectories(); //pEnumServerDirectories.Reset(); //IServerDirectory pServerDirectory = pEnumServerDirectories.Next(); //while (pServerDirectory != null) //{ // if (((IServerDirectory2)pServerDirectory).Type == esriServerDirectoryType.esriSDTypeOutput) // { // string dir = pServerDirectory.Path; // string vdir = pServerDirectory.URL; // break; // } //} // Set the configuration Properties of the MapServer Object IPropertySet pProps = pConfiguration.Properties; pProps.SetProperty("FilePath", pathToMXD); // required property pProps.SetProperty("OutputDir", "c:\\arcgisserver\\arcgisoutput"); string virtualOutDir = " http://" + serverMachineName + "/arcgisoutput"; pProps.SetProperty("VirtualOutputDir", virtualOutDir); pProps.SetProperty("MaxImageHeight", "2048"); pProps.SetProperty("MaxRecordCount", "500"); pProps.SetProperty("MaxBufferCount", "100"); pProps.SetProperty("MaxImageWidth", "2048"); pConfiguration.Properties = pProps; // Set the info segment of the MapServer Object properties IPropertySet info = pConfiguration2.Info; info.SetProperty("WebEnabled", "true"); info.SetProperty("WebCapabilities", "Map,Query,Data"); pConfiguration2.Info = info; // Set the recycle properties of the MapSrver object IPropertySet pProp = pConfiguration.RecycleProperties; pProp.SetProperty("StartTime", "1:00 AM"); // start recycling at midnight pProp.SetProperty("Interval", "86400"); // every 24 hours pConfiguration.RecycleProperties = pProp; // create a mobile server and web enabled pConfiguration2.set_ExtensionEnabled("Mobileserver", true); IServerObjectManager pServerObjectManager = pGISServerConnection.ServerObjectManager; IServerContext serverContext = pServerObjectManager.CreateServerContext(string.Empty, string.Empty); IPropertySet2 extensionSet = serverContext.CreateObject("esriSystem.PropertySet") as IPropertySet2; extensionSet.SetProperty("WebEnabled", "true"); extensionSet.SetProperty("WebCapabilities", ""); pConfiguration2.set_ExtensionInfo("Mobileserver", extensionSet); //' add the configuration to the server pServerObjectAdmin.AddConfiguration(pConfiguration2); pServerObjectAdmin.StartConfiguration(serviceName, "MapServer"); //IEnumBSTR pEnumBSTR = pServerObjectAdmin.GetFolders("arcgisoutput"); //pEnumBSTR.Reset(); //string fName = pEnumBSTR.Next(); //while (pEnumBSTR.Next() != null) //{ // fName = pEnumBSTR.Next(); //} }Thanks in advance!
