Is it possible through ArcGIS Online to republish a feature service (using a Feature Service View or some other mechanism) from an external ArcGIS Server (of which I have no control)?
Here is an example:
Say there exists a feature service on an external ArcGIS Server (example.com).
I would like serve a filtered view of that data as a feature service to share with others (so that the others do not have to connect directly and view the full data at example.com).
From within ArcGIS Online, I can successfully connect the target feature service at example.com.
At this point, normally I would simply utilize the "Create View Layer" feature from within the Feature Layer, however this option does not appear for my connected Feature Service from example.com.
Is it possible that the target/source feature service (the ArcGIS Server at example.com from my above example) is simply blocking this from occurring, or is this not possible at all? If this will not work as envisioned, any ideas for potential alternative solutions?
