I see what you mean!In that case, let's take Alexander's advice and use the LabelPoint of the pArea. Change this: pPoint = pArea.Centroid To this: pPoint = pArea.LabelPoint
Sorry, forgot to show you where the point is appearing. See attached.
Option Explicit Sub CreateCentroid() ''provides access to members that control the MXD Dim pDoc As IMxDocument ''Provides access to members that control the map. Dim pMap As IMap ''Set the MXD to this mxd file Set pDoc = Application.Document ''Set the focus to the current map Set pMap = pDoc.FocusMap ''Provides access to members that hand out enumerated features, ''field collections and allows for the updating, deleting and inserting of features. Dim pFCursor As IFeatureCursor ''Provides access to members that manage a set of selected table rows or features. Dim pSelectionSet As ISelectionSet2 ''Provides access to members that control feature selection. Dim pFSelection As IFeatureSelection ''Set the first layer as the active layer Set pFSelection = pMap.Layer(0) ''Set the selected features Set pSelectionSet = pFSelection.SelectionSet ''set the pfeaturecursor Set pFCursor = Nothing ''Get a cursor from the selected features pSelectionSet.Search Nothing, False, pFCursor ''Provides access to members that identify a polygon and permit controlled access to its inner and outer rings. Dim pPoly As IPolygon4 ''Provides access to members that return properties common to rings and polygons. Dim pArea As IArea ''Provides access to members that define two dimensional points. Dim pPoint As IPoint ''Variable to hold the X coordinate Dim lat As Long ''Variable to hold the Y coordinate Dim lon As Long ''Provides access to members that return and set properties of a feature. Dim pFeat As IFeature Set pFeat = pFCursor.NextFeature Do Until pFeat Is Nothing Set pPoly = pFeat.ShapeCopy Set pArea = pPoly Set pPoint = pArea.Centroid lat = pPoint.X lon = pPoint.Y Set pFeat = pFCursor.NextFeature Loop MsgBox "The Eastings:" & lat & " The Northings:" & lon End Sub
Dim pGraphics As IGraphicsContainer pGraphics = pMap Dim pMarkerElem As IMarkerElement pMarkerElem = New MarkerElement Dim pElement As IElement pElement = pMarkerElem Dim pFCursor As IFeatureCursor Dim pSelectionSet As ISelectionSet Dim pFSelection As IFeatureSelection pFSelection = pMap.Layer(0) pSelectionSet = pFSelection.SelectionSet ''set the pfeaturecursor pFCursor = Nothing ''Get a cursor from the selected features pSelectionSet.Search(Nothing, False, pFCursor) Dim pPoly As IPolygon Dim pArea As IArea Dim pPoint As IPoint Dim pFeat As IFeature pFeat = pFCursor.NextFeature Do Until pFeat Is Nothing pPoly = pFeat.ShapeCopy pArea = pPoly pPoint = pArea.Centroid pElement = New MarkerElement pElement.Geometry = pPoint pGraphics.AddElement(pElement, 0) pFeat = pFCursor.NextFeature Loop pDoc.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeography, Nothing, Nothing) pDoc.ActiveView.Refresh()
Also, am I getting eastings and northings or latitude and longitude here?Thanks again for your generous help.
Option Explicit Sub CreateCentroid() Dim pDoc As IMxDocument Dim pMap As IMap Set pDoc = Application.Document Set pMap = pDoc.FocusMap Dim pFCursor As IFeatureCursor Dim pSelectionSet As ISelectionSet Dim pFSelection As IFeatureSelection Set pFSelection = pMap.Layer(0) Set pSelectionSet = pFSelection.SelectionSet ''set the pfeaturecursor Set pFCursor = Nothing ''Get a cursor from the selected features pSelectionSet.Search Nothing, False, pFCursor Dim pPoly As IPolygon Dim pArea As IArea Dim pPoint As IPoint Dim lat As Long Dim lon As Long Dim pFeat As IFeature Set pFeat = pFCursor.NextFeature Do Until pFeat Is Nothing Set pPoly = pFeat.ShapeCopy Set pArea = pPoly Set pPoint = pArea.Centroid lat = pPoint.X lon = pPoint.Y Set pFeat = pFCursor.NextFeature Loop MsgBox "The Eastings:" & lat & " The Northings:" & lon End Sub
Set pDoc = ThisDocument
Dim pFCursor as IFeatureCursor pFCursor = nothing pSelectionSet.Search Nothing, False, pFCursor
Also, you have specified the lat and lon variables as LONG data type. Why? This would produce a whole number, which I don't know of any Latitude/Longitude coordinate that is a whole number. Is that what you want?
The pSelectionSet.Search(Nothing, False, pFCursor) is appearing in red. I am guessing it should be: pFCursor = Nothing pFCursor = pSelectionSet.Search(Nothing, False, pFCursor)
But now I am getting a run-time error:Run-time error:91 Object Variable or With Block Variable not setWhen I click on debug, it takes me to the following line in code:Set pFeat = pFCursor.NextFeatureThanks again.
Sub CreateCentroid() Dim pDoc As IMxDocument Dim pMap As IMap Set pDoc = Application.Document Set pMap = pDoc.FocusMap Dim pFCursor As IFeatureCursor Dim pSelectionSet As ISelectionSet Dim pFSelection As IFeatureSelection Set pFSelection = pMap.Layer(0) pSelectionSet = pFSelection.SelectionSet ''set the pfeaturecursor pFCursor = Nothing ''Get a cursor from the selected features pSelectionSet.Search(Nothing, False, pFCursor) Dim pPoly As IPolygon Dim pArea As IArea Dim pPoint As IPoint Dim lat As Long Dim lon As Long Dim pFeat As IFeature Set pFeat = pFCursor.NextFeature Do Until pFeat Is Nothing Set pPoly = pFeat.ShapeCopy Set pArea = pPoly Set pPoint = pArea.Centroid lat = pPoint.X lon = pPoint.Y Set pFeat = pFCursor.NextFeature Loop End Sub
Option Explicit Sub CreateCentroid() Dim pDoc As IMxDocument Dim pMap As IMap Set pDoc = Application.Document Set pMap = pDoc.FocusMap Dim pFCursor As IFeatureCursor Dim pSelectionSet As ISelectionSet Dim pFSelection As IFeatureSelection Set pFSelection = pMap.Layer(0) Dim pPoly As IPolygon Dim pArea As IArea Dim pPoint As IPoint Dim lat As Long Dim lon As Long Dim pFeat As IFeature Set pFeat = pFCursor.NextFeature Do Until pFeat Is Nothing Set pPoly = pFeat.ShapeCopy Set pArea = pPoly Set pPoint = pArea.Centroid lat = pPoint.X lon = pPoint.Y Set pFeat = pFCursor.NextFeature Loop End Sub
set pFSelection = pMap.Layer(0)
pDoc = m_pApp.Document
Dim pDoc As IMxDocument pDoc = Application.Document
Sub CreateCentroid() pDoc = m_pApp.Document pMap = pDoc.FocusMap Dim pFCursor As IFeatureCursor Dim pSelectionSet As ISelectionSet Dim pFSelection As IFeatureSelection pFSelection = pMap.Layer(0) Dim pPoly As IPolygon Dim pArea As IArea Dim pPoint As IPoint Dim lat As Long Dim lon As Long Dim pFeat As IFeature IFeature = pFCursor.NextFeature Do Until pFeat Is Nothing pPoly = pFeat.ShapeCopy pArea = pPoly pPoint = pArea.Centroid lat = pPoint.X lon = pPoint.Y pFeat = pFCursor.NextFeature Loop End Sub
So, I am not certain if the VS IDE Framework is what you need. I do believe that the reason why no ArcGIS Project templates show up is because you simply do not have the ArcGIS .NET SDK installed.
I think I need ArcGIS Visual Studio Integration Framework!Is there any other way I can acheive this? i.e. build a custom tool based on a model?
I *think* this is because you do not have the ArcGIS .NET SDK ("Developer Kit") installed. Can someone else confirm this?
James, I am trying to create an Add-In following this link:http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//0001000001ms000000But I cannot find ArcGIS node under project type. What do I need to do in order to get that in Visual Studio?I apologise for these questions as I am a bit of a beginner in Arc.I will be adding this to ArcMap and hopefully, once it is up and running, my colleagues will be using it too.Thanks.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und mehr. Neu hier? Registriere ein kostenloses Konto.
