Hi Jonathan Quinn
We have an ArcGIS Enterprise 10.6.1. environment. I have powershell scripts that do a full webgisdr backup on Sundays and incremental backups every other day.
The VM servers are also backed up everyday using Commvault as part of our organisations enterprise backup policy.
My first restore strategy would be to restore from the webgisdr tool given the interdependency between Portal, Server and the Data Store. However, if the webgisdr restore process failed for some reason I would then try and restore from VM. I understand that a restore from VM can be problematic due to the timing of the backups . I notice you wrote in a previous GeoNet question
"Some organizations rely on VM backups, but they have to be timed correctly with file server backups so you capture the data of the entire deployment at a point in time. If you take backups at different times, you'll have differences in the dependencies between Portal, Server, and Data Store which will cause issues when you attempt to restore the backups"
So I contacted our backup provider to check whether or not VM backups all occur at the same time. The response I got was that the backups are scheduled to all start at the same time however because of the way Commvault performs resource management it cant be guaranteed that all of the backups will start at the same time. This is done so as to not flood the VM environment. Essentially they are queued and run through in sequence.
My question is how close together do the backups need to be performed. Is within the same hour ok ? (this is out of business hours and no updates to the system should be taking place). Or do the backups all need to be done at the precisely the same instant?
Clinton
