I'm working with some data that is a ridiculously large table (184 fields) and I would like to asses how many instances of of each field are non-null. In other words if the values are more more often null, I'll drop the field(s). For now I've written a script that performs an iterative selection for each field, and as you can imagine with 184 fields and a few thousand records it's pretty slow. I tried a couple other approaches that failed, but I have to think there is a better way to get a count of records for which a given field is populated. Here is what I've done to date:
<SPAN class="keyword token">import</SPAN> arcpy
table <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'J:\some\path\to\file.gdb\tableName'</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> f <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
fields<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeTableView_management<SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'tv'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> f <SPAN class="keyword token">in</SPAN> fields<SPAN class="punctuation token">:</SPAN>
select <SPAN class="operator token">=</SPAN> f<SPAN class="string token">'{f} is not null'</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'tv'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'NEW_SELECTION'</SPAN><SPAN class="punctuation token">,</SPAN>select<SPAN class="punctuation token">)</SPAN>
c <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'tv'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Field {} has {} non-null records'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">,</SPAN>c<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
