arcpy.un.SetSubnetworkDefinition(
in_utility_network=r"",
domain_network="Water",
tier_name="Pressure Boundary",
support_disjoint_subnetwork="SUPPORT_DISJOINT",
valid_devices="Telemetry/Unknown;Telemetry/ClearWell;Telemetry/Tank;Telemetry/StandPipe;Telemetry/PumpStation;Telemetry/MeterStation;Telemetry/PressureRecorder;Telemetry/MotorizedValve;Hydrant/Unknown;Hydrant/Hydrant;Valve/Unknown;Valve/AirRelease;Valve/Altitude;Valve/BlowOff;Valve/Butterfly;Valve/Check;Valve/Gate;Valve/LevelControl;Valve/PostIndicator;Valve/PressureRegulator;Valve/RPZ;Valve/Pito;Valve/FireService_Val;Valve/PressureBoundary;Valve/Stub_Val;Valve/Abandoned_Open;Valve/Abandoned_Closed;Meters/Unknown;Meters/Meters",
valid_subnetwork_controller="Telemetry/PumpStation;Valve/Gate;Valve/PressureRegulator",
valid_lines="HydrantLead/Unknown;HydrantLead/HydrantLead;Laterals/Unknown;Laterals/Laterals;Main/Distribution;Main/FireService_Lead;Main/Stub;'Main/Wash Water';'Main/Settled Water';'Main/Filtered Water'",
aggregated_line="Main/Distribution;Main/FireService_Lead;Main/Stub;'Main/Wash Water';'Main/Settled Water';'Main/Filtered Water'",
diagram_template=None,
summaries=None,
condition_barriers="ValveStatus IS_EQUAL_TO SPECIFIC_VALUE 2 AND;'Asset group' IS_EQUAL_TO SPECIFIC_VALUE 3 AND;'Asset type' INCLUDES_THE_VALUES SPECIFIC_VALUE (3,6,7,10,11) #",
function_barriers=None,
include_barriers="INCLUDE_BARRIERS",
traversability_scope="BOTH_JUNCTIONS_AND_EDGES",
propagators=None,
update_structure_features="UPDATE",
update_container_features="UPDATE",
edit_mode_for_default_version="WITHOUT_EVENTING",
edit_mode_for_named_version="WITHOUT_EVENTING",
valid_junctions="Fitting/Unknown;Fitting/Bend;Fitting/Cross;Fitting/EndOfMain;Fitting/Tee;Fitting/Plug;Fitting/Reducer;Fitting/Sleeve;'Fitting/Plugged Tee';Fitting/Increaser;Fitting/Coupling;PipeHop/Unknown;PipeHop/PipeHop;Water_Net_Junctions/Water_Net_Junctions;MeterBox/Unknown;MeterBox/MeterBox",
valid_junction_objects=None,
valid_junction_object_subnetwork_controller=None,
valid_edge_objects=None,
manage_subnetwork_isdirty="NOT_MANAGE",
include_containers="INCLUDE_CONTAINERS",
include_content="INCLUDE_CONTENT",
include_structures="INCLUDE_STRUCTURES",
validate_locatability="DO_NOT_VALIDATE_LOCATABILITY"
does this condition work like ValveStatus == 2 AND AssetGroup == 3 AND AssetType IN (3,6,7,10,11)
Any advice on this is much appreciated.
Thanks in advance
