Hi there,
I have a deployment using Azure blob for the cloud object store @ 12.0. I am seeing ArcGIS Server backups fail once they get over a certain size, or if I attempt to include object store caches in the backups. I get this message in the webgisdr logs:
"name": "ArcGIS Server",
"messages": "Cannot access the backup file for ArcGIS Server in webgisdr-backup/12-0-0/backup/20260505-091107-backup\\server\\cd67fdf9jcwpzzk6.",
"URL": "https://xyzxyzxy/hosting",
"status": "failure"
Latest job status of async backup operation on server https://xyzxyzx/hosting: {"jobid":"j65e79912-4aaa-46d3-8b8d-0717760d431b","stepInfo":["Export operation started.","Export operation failed."],"status":"EXECUTING"}.
"{"jobid":"j65e79912-4aaa-46d3-8b8d-0717760d431b","status":"COMPLETED","stepInfo":["Export operation started.","Export operation failed."],"operationResponse":{"status":"error","messages":["Export operation failed. Failed to write the file '20260505-091124.agssite' to this location 'webgisdr-backup/12-0-0/backup/20260505-091107-backup/server/cd67fdf9jcwpzzk6'"]}}"
looking at a manual export of that site from the admin API I get:
Failed to write the file '20260505-095011.agssite' to this location 'backup-20260504' Failed to upload backup-20260504/20260505-095011.agssite to object store.. Caused by: Timeout on blocking read for 300000000000 NANOSECONDS
Export operation failed. Failed to write the file '20260505-095011.agssite' to this location 'backup-20260504'
which is an exception in:
Caused by: Timeout on blocking read for 300000000000 NANOSECONDS at com.esri.arcgis.objectstore.clients.azure.AzureBlobStoreClient.putObject(AzureBlobStoreClient.java:986) at com.esri.arcgis.objectstore.clients.azure.AzureBlobStoreClient.putObject(AzureBlobStoreClient.java:915) at com.esri.arcgis.discovery.admin.backuprestore.BackupRestoreUtil.writeSiteFileToBackupStore(BackupRestoreUtil.java:888)
This worked at 11.5, there was a change from staging everything locally first before uploading to writing directly to blob storage at 12.0. We are using private endpoints to access the storage and should have a clear path to it.
I have seen two bugs with 12.0 but don't know if this is related to what I'm seeing:
https://support.esri.com/en-us/bug/large-web-gis-disaster-recovery-webgisdr-exports-fail-t-bug-000176368
https://support.esri.com/en-us/bug/after-migrating-hosted-scene-layer-caches-from-the-tile-bug-000173313
If anyone has hit this have you got a cause / solution? I'm going to staging locally and uploading to blob in the meantime.
Thanks!
