The Space Planner allows you to allocate spaces to specific groups, based on values in the ORG_LEVEL_1 field of the Occupants layer. For larger orgs, it could be beneficial to have multiple fields to work with. ORG_LEVEL_1 might be Department and ORG_LEVEL_2 might be Team. In some cases, the organization might want to allocate some spaces for use by any Team in the Department, while other spaces are only allocated to one specific Team.
Related to this idea, it would then also be nice if the Space Planner allowed you to choose what field(s) the Allocation functionality uses for increased flexibility, rather than requiring the use of the ORG_LEVEL_1 field, ORG_LEVEL_2 field, etc.. For visualization purposes, it would be nice to be able to toggle the map visualization based on those different levels, and to search/filter for allocated units based on these multiple fields.
While our org specifically would like to see at least three levels, even just allowing for one additional level of organization using the default ORG_LEVEL_2 field would be a big help.
