I have an SDE of about 40,000 addressing points - when I share this layer to our Portal and try to view the Feature Layer in Map Viewer, the points show up initially, but after zooming out a couple of times, the points disappear from the map. And then, they never come back. The attribute table shows all of the data, but there is no longer any geometry. The Map Image Layer works fine - and if I open the Feature Layer in Map View Classic, it shows up. I need to be able to have this layer editable (and visible), so that another department can add and change addresses as needed. Any ideas on why this layer is not visible on the map?
