Hello
I am trying the new Waste Collection Layer, which looks like a useful tool. I followed these documentation and tutorial links to set up and run:
https://pro.arcgis.com/en/pro-app/latest/help/analysis/networks/waste-collection-analysis-layer.htm
https://pro.arcgis.com/en/pro-app/latest/help/analysis/networks/waste-collection.htm
However, when running with 'Any Vertex' mode in the Network Dataset, I get the following error:
ERROR 030024: Solve returned a failure.
Internal error in CreateCollectionEdge: overlapping edge ranges. (code 6121).
Cannot find the above error online - is it new to ArcGIS Pro?
I have tried fixing the network using the 'Pairwise Integration' tool, but still getting the same error. If I use the 'Endpoint' setting in the Network Dataset, the solver can't reach more than 30% of the Stops. There may be other connectivity issues in the Network Dataset, but I don't know where they are or how to fix them.
Any suggestions on how to fix the above error or network errors, please post replies.
Thank you
