I have query that uses common tables via a WITH clause. It works fine in SSMS, but doesn't seem to run in the Add Query Layer tool. Simple example below:
WITH my_cte AS (
SELECT *
FROM my_table
SELECT *
FROM my_cte Invalid SQL syntax[[Microsoft][ODBC Driver 17 for SQL Server][SQL Server]Incorrect syntax near the keyword 'WITH'.]
Is there some sort of restriction or syntax difference for CTE tables in ArcGIS Pro?
This query is being run against a separate SQL Server 2022 database via an SDE connection, not an Enterprise Geodatabase.
