Hello!
Right, picture this, you're in Indoors Viewer, all your buildings will be showing the level 0 from the Vertical Order field - let's call this Base Level. You navigate to a specific building with the Indoors widget and start flicking in between floors. The other buildings remain showing their Base Level. One building's first floor actually extends directly above the Base Level of another building. Oh, what's this, the other building's Base Level is coming through showing the walls in the first floor of the other building.
Is this a familiar situation for people?
I thought maybe I was doing smth wrong, but couldn't find a defined approach to avoid this.
I have come up with a workaround, which I'm happy to share, but also I'll be content if someone can point out a standard approach for dealing with this.
Ciao
SCB
