I'm using distributed collaborations to share copies of hosted feature layers from ArcGIS Enterprise to ArcGIS Online.
When I update the field alias (display name), field description and field value type of the portal item in ArcGIS Enterprise (using the data tab), only the field alias persists in the copied item in ArcGIS Online if I share it to the collaboration group.
I would like for all the configurations (field aliases, descriptions and value types) in the portal item in ArcGIS Enterprise, to persist in the copy in the receiving portal.
- Is it possible to make this an optional enablement so that all the changes carry over, not just the field alias?
Table view in ArcGIS Enterprise
For items already shared via distributed collaboration:
- Ideally, this would work for items that already participate in a distributed collaboration. I've noticed that the field alias passes through to the item in the receiving portal (ArcGIS Online) when I add an item to the collaboration group. However, this is not the case if the item is already shared.
- For items that are already shared via distributed collaboration, not even the field aliases carry over if I add them to the portal item in the sending group. For example:
- I have a hosted feature layer that is collaborated from my Enterprise portal to my ArcGIS Online organization using distributed collaboration.
- I update the attribute table in the version in ArcGIS Enterprise (sending group) with field aliases, descriptions and value types.
- No change appears in the corresponding item in ArcGIS Online (receiving group).
- I try editing the item details e.g. description in the ArcGIS Enterprise version. The updated description appears in the corresponding item in ArcGIS Online but the attribute table does not reflect any of the changes I made.
- The only way I've been able to get the field alias to pass through is to un-share the item and re-share it through the distributed collaboration. I would prefer not to do this since my item has dependencies.
- Ideally, I would also like the field descriptions and value types to also pass through in this case, too, not just the field alias.
Below is the table view in ArcGIS Online
Table view in ArcGIS Online
Previous post about this: Field descriptions and value types do not persist ... - Esri Community
