Hello!
I'm working on building a prototype utility network using the Essentials Sewer Utility Network Foundation. So far, it's going well, and there's a lot of documentation available. Here's what I've done so far:
- Simple data mapping
- Migration workspace
- Load data using workspace
- Asset package to GDB
- Enable network topology
- Working on network errors
As I go through this process, I have some random questions.
- Has anyone noticed that the Sewer Utility Network Essentials package is missing some things? I found documentation stating what should be included with the solution package, like instructions, workflow examples, and another map to support editing. The solution I downloaded seems to missing a lot of this…I downloaded it in June 2025 and using ArcPro 3.5.1
Introducing Utility Network Foundations
What is included in a Utility Network Foundation?
Each Utility Network Foundation includes:
- Instructions
- An Asset Package containing schema for components that typically make up the domain network and rules to define network behavior
- A map to publish the utility network service for the domain network
- A map to support editing
- Workflow examples
- Sample data
- I noticed the required network attribute field "Operable" doesn't have the coded domain set up? The videos I watched looks like it should be. Im wondering if there is a reason for this? Or possibly a mistake in the preconfigured model.
- I'm wondering about the map included in the foundation package. The table of contents has clean lines connecting everything. Is this just a display setting? When I created my utility network and added it to a map, I don't see these lines. Should I be seeing them with a proper UN setup. See attached.
- Lastly, I'm wondering how I can create sub-networks. I've seen some things suggesting I can use an ancillary role field to automate this setup. I know there's a tool to modify the subnetwork controller, but I'm interested in using my ancillary role field somehow. Is there any good documentation on this if possible?
Thanks!
