I am looking to implement more URL parameters in an Experience Builder that contains almost 20 layers. I would like to dynamically create parameters for each layer based on a particular ID attribute in that layer.
However, the difficulty for this is that the data source name is not intuitive, something like datasource_2-abcdefgh-layer30, and that is hard to set up for allowing dynamic URLs for all layers.
Does anyone have experience working around this and having the data source name be a bit more intuitive (e.g., using the layer item portal ID instead?) - for example, in ArcGIS Assistant in JSON?
If there is no reported workaround for this, I can submit an ArcGIS Idea to see if the data source ID can be shifted to the actual layer item ID.
