Hello. I have build several forms in Field Maps Designer, and have used them for about 1.5 weeks now. For each layer that has a form, I have one field with a calculated expression to automatically generate a number for each new feature created in the later (simply adding 1 for each new feature). I also have set most fields in the layers to being required. I have gone in and tested the forms repeatedly as we are getting ready for our first field season of using Field Maps, and this morning I got onto the Field Maps Designer web app to create a new offline map and noticed that the form is no longer automatically generating id#s, and it is also not requiring any fields be filled in when I add a new feature. Does anybody know what could have caused my forms to stop working in these ways? I thought I could reset the calculated expression but I can't find a way to even access that in the forms on Field Maps Designer anymore. So, it seems I'll have to re-make the forms completely if I want an id number automatically generated.
Thank you!
