Hi - I've updgraded Maps SDK to 4.32 and have also upgraded Angular from 18 to 19. I'm getting a bunch of the following error and layers dont appear when I hit a map in my development/debug environment (visual studio code 1.84):
ErrorEvent {isTrusted: true, message: 'Uncaught NetworkError: Failed to execute 'im…nks/285dd7683f57d9d3667d.js' failed to load.', filename: 'http://localhost:4200/assets/esri/core/workers/RemoteClient.js', lineno: 1, colno: 109155, …}
i2 @ c:\Angular\DigAlert\node_modules\@arcgis\core\core\Logger.js:98:12
Things I've done:
Verified that RemoteClient.js is within the folder above.
Changed the config.assetsPath from original: 'assets/'; to /assets/ (and tried several others ./assets/, ../assets/)
Deleted my browser history
When I publish to my server test site there are no errors, so its definitely a local problem with my debug environment.
Strange:
There are a number of maps in my app. When I changed config.assetsPath from 'assets/'; to /assets/ in just one of the maps, everything worked -- no errors and layers appeared in all maps. I thought I had the problem solved at that point, but when I changed config.assetsPath to the new value in another map it started throwing errors again
Any ideas what I should try to get this fixed?
Pete
