Project Overview:
I am currently developing a project aimed at simulating the potential flooding effects due to high tides. The study area includes agricultural land and other vulnerable regions protected by a set of discontinuous dikes. These dikes are intended to mitigate the impacts of tidal flooding, which would otherwise inundate the area during high tides. To aid in flood risk analysis, I have acquired a high-resolution (1 meter) Digital Elevation Model (DEM) of the study area and intend to generate a series of maps depicting the extent of inundation at varying water levels.
Project Goals and Requirements:
The primary goal of this project is to produce flood projection maps for a 100-year period, considering a sea-level rise scenario of 2 meters above the current Mean Higher High Water at Large Tides (MHHWLT) value. Specifically, I seek a detailed, step-by-step procedure for generating these maps, including methods for representing both the current water surface and the MHHWLT in my model.
Specific Questions and Areas of Concern:
Generation of Water Surface and MHHWLT Layers: How can I create a layer that represents the current water surface, as well as one that represents the MHHWLT for the study area?
Incorporating the Impact of Tides: What is the best approach to incorporate tidal fluctuations into this model, given the dynamic nature of tides and their contribution to the inundation extent?
Consideration of Sea-Level Rise: How should I factor in a 2-meter sea-level rise scenario into the flood model, and what methodologies can be applied to project its impact over the 100-year period?
Software and Tools:
I am currently using ArcGIS Pro 3.2 for this analysis and would greatly appreciate guidance on utilizing this software effectively for the tasks outlined above.
Conclusion:
I would greatly appreciate any recommendations or advice that could help streamline the development of accurate and reliable flood projection maps. Thank you for your time and support.
