Hello,Hopefully one last question. I've got my kml file to load, and I can set the color based on an attibute, but here's my problem...When my KML file is loaded, all of the polygons are filled white. I can lessen it by setting the whole kml layer opacity to .5, but once the color is applied, the remaning countries are filled with white. A workaround I came up with is: Dim theKmlLayer As ESRI.ArcGIS.Client.Toolkit.DataSources.KmlLayer = CType(Map1.Layers("MyGraphicsLayer"), KmlLayer)
Dim fillsymbolcolor As New SimpleFillSymbol
Dim fillsymbolclear As New SimpleFillSymbol
fillsymbolcolor.Fill = New SolidColorBrush(Color.FromRgb(255, 0, 0))
fillsymbolclear.Fill = New SolidColorBrush(Color.FromArgb(0, 0, 0, 0))
theKmlLayer.Opacity = 0.5
For Each kl As GraphicsLayer In theKmlLayer
For Each g As Graphic In kl.Graphics
If CStr(g.Attributes("name")) = "United States" Then
g.Symbol = fillsymbolcolor
Else
g.Symbol = fillsymbolclear
End If
but surely there's a way to have the kml file itself come in w/ clear polygons. If anyone is interested, my kml file is attached. Ideally, I'd like to KML file to load w/ the polygons not being filled rather than having to loop through every one and apply a clear fill to it. Thanks in advance!
