Hey all,
I created a domain within a project with Yes and No as the only 2 codes available and it worked as it should. I now need to add another domain for a different field. I can add the domain with no issue, however, as soon as I attempt to add a code to the new domain I lose the ability to save the domain. The domain and the codes go from having the green square to a red square next to them and I can go no further in the process just by adding the code line. If I remove the code lines I can again save the domain and even add it to the desired field. any idea what might cause this?
