Hey,I am playing around with the UniqueValuesSymbology class introduced at 10.1. It looks like the properties of the layer symbology is passed into python lists (i.e. classValues, classLabels)I edited the script example from the help menu to update the classValues based on a list built from values in a field ('SMU') in a feature class. This works fine. What I am struggling with is, after the class Values are updated, I want hard code the matching classLabels (or use a look up table) to update the label based on values in the classValue. So just an if statement to say something like. if lyr.symbology.classValues == "M1":
lyr.symbology.classLabels = "Test"
I understand why this kind of is statement isn't working because the properties are python lists. So, I'm thinking I need to build 2 lists, one for the classValues and then one for the classLabels, but I'm just not sure how to go about it. Here's is my code:
import arcpy
mxd = arcpy.mapping.MapDocument(r"Z:\Test.mxd")
lyr = arcpy.mapping.ListLayers(mxd, "Soil Map Units_temp")[0]
smuList = []
rows = arcpy.da.SearchCursor(lyr, ["SMU"])
for row in rows:
smuList.append(row[0])
if lyr.symbologyType == "UNIQUE_VALUES":
lyr.symbology.classValues = smuList
lyr.symbology.showOtherValues = False
# this is my pseudo code. In essence, this is what I want to do. Update the classLabel based on the values from classValues
Any suggestions are welcome.Thanks,Mike
